Have I bought a fake?
I have just bought a Sandisk Extreme Firewire Reader.
There is no file recovery software disc and for the life of me,
I can not find the serial number on either the box nor the reader..
I have downloaded the recovery software from Sandisk, but I need to activate it by supplying a serial number, which I do not seem to have.
Does anyone else out there have the same issue, and where do I find the serial number?
Thanks.
Re: Have I bought a fake?
The model number is SDDRX4-CF-904
Message Edited by AJP on 06-03-2010 01:02 AM
Re: Have I bought a fake? NOT SOLVED
Not sure what the accepted solution tick of approval is??
NOT SOLVED
Message Edited by AJP on 06-03-2010 01:04 AM
