Accepted Solution
FireWire 400/800 for 40MB/sec
This may seem like an easy answer, but I'm curious.
What connection is best for the top transfer rate of 40MB/sec?
I'm using FW800 right now as...well...FW800 is fastest. However, can you achieve the 40MB top transfer rate using FW400?
Thanks
Re: FireWire 400/800 for 40MB/sec
you will see the fastest speeds when connected to the FW800 port
