Highlighted
Extreme Firewire Reader
Hi All
Will an ExpressCard 34 firewire 1394b adapter work with the Extreme Firewire Reader?
Thanks
Highlighted
Re: Extreme Firewire Reader
Also, one forum member has reported that a 9 to 4 pin cable worked on a Dell laptop, I've got a Dell laptop and I've splashed out £4.99 on a cable so I'll report the results......
Anyone else had similar success?
Highlighted
Depends on the cable or adapter you are using.
