Newbie
drive will no longer mount on mac
I just got a Extreme portable ssd and I put some files on it from my imac and plugged it into my macbook pro and I was using a file on it and the drive unmounted and I couldnt get it to remount. Opened disk utility and it faintly showed the drive but I couldnt do anything with it, Anyone know what to do?
Newbie
Re: drive will no longer mount on mac
I have exactly the same problem. It wont mount on mac and pc.Have you found a solution?
Newbie
Plugged into different PC and it worked...and then back into same Mac and it worked. Also saw there were chats on Apple support community and even videos on youtube talking about exFAT working / not working with MACs. If the issue replicates I will update.
Newbie
Have you tried flipping the cable? Just flip one end on the computer side.
It's supposed to be reversible but in my case, sometimes it does not work.
Or try another cable.
https://forums.sandisk.com/t5/Extreme-Portable-SSD/Cable-Problem/td-p/370409
Newbie
same problem here
Newbie
facing the same problem here
Newbie
I have found if I keep it connected it will show up again, but for me eventually the same thing happens and again I stop working and wait for it to remount. I have the same problem with a Samsung t5 drive
