Newbie
Cable Problem
SanDisk Extreme SSD 2TB not detected on Windows 10 depending on how the cable is connected.
The plug on the drive side and be plugged in 2 ways (normal and flipped).
The computer side also 2 ways.
For the 4 possible cases, there is 1 case where the drive does not get detected.
Not in Explorer, Device Manager nor in Computer Management (using Win 10).
I can hear the connect/detect sound but device does not appear.
This only happens on a particular USB-C port on my computer,
the other port works in all cases. If I use a different cable (not from SanDisk),
all 4 cases works in any port.
I also tested the cable from another Extreme 1TB, same problem.
Tested SanDisk's cable on a phone, no problem.
I suspect a problem with SanDisk's cables.
Has anyone experienced this and found a solution?
Newbie
Re: Cable Problem
I connect it to various ports and OSs without issues, but I have noticed that disk (1 TB) overheats if I'm using original cable (which includes USB-C to USB-A adapter) but it just warms up a little (which is expected) if I'm using my phone's charging cable (without adapter)
SanDisk User
Re: Cable Problem
SanDisk User
Re: Cable Problem
[ Edited ]
@BRITANY wrote:
@Damir wrote:
I connect it to various ports and OSs without i  Audacity Find My iPhone Origin ssues, but I have noticed that disk (1 TB) overheats if I'm using original cable (which includes USB-C to USB-A adapter) but it just warms up a little (which is expected) if I'm using my phone's charging cable (without adapter)
