Accepted Solution
max environment temperature of 4GB extreme IV cf
Hello ,
I'm produce an electronic equipement with an embedded pc.I use cf extreme IV 4GB.
The specification says max 85 C , but this data is environment temperature or the max junction temperature?
(there is a sopraelevation temperature due to internal activity?)
For example if the environment is at 60 C is ok for the cf?
Thanks
Gulfio
Re: max environment temperature of 4GB extreme IV cf
There use to be a document up on the SanDisk web site, but now i can not find it... but I am pretty sure they mean an environment temperature.
the operating temp for extreme IV line is -25 to 85 C
