Accepted Solution
Sandisk CF Extreme 4 compatibility
Hi just got a new Olympus E410 DSLR and a Sandisk Extreme 4 CF card to go with it. I just inserted my card and it doesnt seem to be working. First of all it says the crd is full, then when i try to format it through the cameras menu it displays the message ' card error'. Can anyone please tell me whether or not their is an error with the card or is it just not compatible with my camera? Im new to this so please help!
thanks
Re: Sandisk CF Extreme 4 compatibility
Quick question--what is the capacity of your Extreme IV card?
Where did you buy your card from? Also have you tried the card in any other devices, like a card reader on your computer, or a different camera?
Just bought an Oly E-520 and my Extreme IV works just fine
I have just bought a 410 as well and an Extreme IV 4GB card and have exactly the same format card error problem. Reads full until I format and then card error. The card works fine in a card reader on the PC and have also updated the firmware to the latest version 1.3. Any ideas would be most welcome.
