Accepted Solution
4G CF becomes 2G
I bought a Extreme III 4G card. I used it in one of my camera. It said CF error and format it. But now the card is 2G on the computer. How can I do to make it back to 4G?
Re: 4G CF becomes 2G
Well, a questions first...
What model camera do you have?
Also, if you use a card reader on your computer, do a Google search for HP Disk Storage Format Tool and download it.  Run it with the card in the reader and it should get you back to 4GB.
It works. Thanks a lot.
