Accepted Solution
Extreme 60mb/s 16gb Card rattles
I just bought this card and it works fine so far but out of the camera if shake it or tap it I can hear a the rattle of something inside. I have never had this issue with a CF card. Is this normal for this card?
Thanks for your help.
Re: Extreme 60mb/s 16gb Card rattles
rattling is not normal but really should not hurt the card.
Mine started rattling as well. Can someone from the company expain this and put me at ease that I am not suddenly going to loose media. Otherwise how can I go about getting a replacement? Does Sandisk stand by their quality?
the cards have a lifetime warranty so contact their support. 866-sandisk
