Card manufacture question
Are all Extreme cards produced out of the same factory?
Reason I ask is I just bought one off 1800Memory on eBay and both the card and the packaging differ slightly to the one I got from a shop when I had an Extreme III fail.  I might be able to get some photos later if it helps.
I'm just concerned that the card I have just bought might not be genuine, although there is a report that the sell I bought from does provide genuine SanDisk products.
Re: Card manufacture question
sandisk has changed packaging and card labels several times over the past few years. best bet is to contact sandisk support to verify authenticity 866-sandisk
