Accepted Solution
32 GB, Extreme, 60 MB/s not recognised by card reader
I'm happy Sandisk user (I've already bought 7 Sandisk cards) till now.
Now I've bought CF 32 GB Extreme 60 MB/s. And now I have a problem:
When instaling CF into card reader (on W7 64) it starts to make consecutive sounds like when you attach new USB hardware and can not read it. Also Canon's Zoombrowser doesn't start to dowload images from CF. The only way to get images down is from connectind 5DII via USB cable directly.
I'm not happy with this. I've formated card on camera. What is going on??? Is it malfunction and needs to be replace?
Re: 32 GB, Extreme, 60 MB/s not recognised by card reader
It seems noone from Sandisk cares about my problem of pro photographer ... :smileysad:.
if the card works normally when connected via the camera and usb cable and also works normally when taking pictures in the camera then the card seems to be good. what type of card reader are you seeing the issue with? also if you have a different CF reader do you see the same issue? and finally to rule out an OS issues with the reader can you try connecting the reader to a different OS like XP and see if you see the same issue?
