Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
![]() Posts: 0
sticky retractable piece on micro 8 GBOptions
11-27-2007 03:53 PM
Hi; I just recently bought an 8 gb cruzer micro. When you retract the usb connector fully, it kind of sticks and then snaps back a mm or two, and if you view it from the side you can see significant angle where the USB sticks out from the plastic case, where it should probably be straight. I thought maybe it was just the one, so I exchanged it for a different one and this one is the same.
I also have a 4 GB micro hat I have been using for over a year, and despite being almost the same product, doesn't mimick what i just explained. Is this normal for the 8 GB micros? Thanks |
