Highlighted
Accepted Solution
Removed software now it doesn't work
I baught a 1gb sdcz6-1024 just for the purpose that I have other thumbdrives. When I plugged it in I found all kinds of software I didn't want or need. My computer found a G drive and an H drive. Somehow I got to a screen that allowed me to remove the software on it and I selected that. Now I can't access anything. No G or H drive. It recognizes that I have it connected but not as a drive. I can't do anything with it. It is useless.
Is there anything I can do to get it back?
Highlighted
Re: Removed software now it doesn't work
Did you disconnect the drive then reconnect it to your PC?
Highlighted
Yes I did I have rebooted since then and plugged it in to two other computers successfully.
Highlighted
check disk managment for a drive letter conflict
