Accepted Solution
Micro Zruzer does not show LED light except when inserted
I have just purchased two Cruzer micor 1 GB black USB drives. Both the drdives only flash the LED when I insert them into the USB port. I have removed the U3 software as i only use them for data storage.  Why do thes drives not show any steady LED light as  does my titanium 2 GB Cruzer drive? I have used other cruzer usb drives and also tried other manuf.drives but they have always had a Lit LED after I insert it into the Port.
 Bryan
Re: Micro Zruzer does not show LED light except when inserted
it depends on the controller that is used in the device. SanDisk has changed the controller they use in the Cruzers and the LED behavior is not to only blink during initialization and file transfer. during the stand by state the LED will not be on.
does it still allow data access?
If not, see my post on:
Message Edited by goingpsycho on 01-09-2008 10:16 PM
