Low Temperature Operation
We deliver the Micro U3 Cruzer in an embedded system using the uCLinux OS.
What is the coldest temperature we might expect the drive to write/read reliably, as it is rated as commercial temperature range?
Re: Low Temperature Operation
You may have to contact SanDisk OEM to gain this information...
Message Edited by Warl0ck on 01-14-2008 06:06 AM
Message Edited by Warl0ck on 01-14-2008 06:07 AM
Hello dordiwiwitness,
There is no documentation that states the operating temperature range of the retail Cruzers. However, our OEM Flash Drives do have this documentation and the Cruzer Micro should be similar if not the same.
Temperature
• Operating: 0° C to 45° C
• Storage: -20° C to 60° C
http://www.sandisk.com/assets/File/pdf/datasheet-ufd.pdf
