Highlighted
Do I still need a pagefile?
I am running Windows Vista and 4GB Cruzer Micro, can I Just use Readyboost and dump the pagefile on my HD or do I need  both?
Thanks
Highlighted
Re: Do I still need a pagefile?
you should keep both.
Highlighted
Thanks for the reply.
Would there be any performane gain by placing the pagefile on the the flash drive?
Highlighted
Moving your page file to your usb drive would be a terrible idea.  The whole point of the ready boost in vista is to make accessing small files that are commonly used really fast.  It's basically a page file for a page file.  Hard drives have a lot higher access and through put rate for sequencial data, but are terrible when it comes to small "random" bits of data.  Flash drives are a lot better for the small stuff.  Hence, the readyboost to speed up.
I don't even know if that would be an option to move it to the drive.  Your system would probably crash if your drive were disconnected prior to windows shutting down.
