Briefcase
I have recently purchased a Cruzer 4 GB.  I am trying to get Windows Briefcase working.  I can create Briefcase and copy some files over.  However, once I get more than about 500MB copied, it says that the disk is full.  I then get a write error.  When I remove the disk and reinsert, all the files in the Briefcase are orphaned.
Did I get a defective drive?
Re: Briefcase
can you copy other data normally to the device? try testing the device by coping other data to the device. see if you get the same error.
