Accepted Solution
CruzerSync not copying new folders and their contents
Using CruzerSync V6.2.042. with Windows XP Professional and a Cruzer Micro 4gb. Any new folders created in the "My Documents" folder are not synchronized with the flash drive. When I select "File Options" from the options menu the new folder is not checked. Do I have to manually check any new folders I create to get them to synchronize with the flash drive?
Re: CruzerSync not copying new folders and their contents
That is just how CruzerSync works.  If you are interested in a more feature filled version, contact Dmailer to see if they have any version that does what you want.
https://support.dmailer.com/client/contact.jsp
Use SyncToy 2.0 by Microsoft. It provides the feature you are requesting
