Highlighted
Newbie
Water ring vacuum pump unit
Water ring vacuum pump unit can be understood as water ring vacuum pump closed cycle system, water ring vacuum pump negative pressure station, roots water ring vacuum unit. This kind of product is called water ring vacuum pump unit in the minds of the majority of users. The following is a brief introduction of the composition and function of each water ring vacuum pump unit:
Water ring vacuum pump closed cycle system: the water ring vacuum pump closed cycle system is generally composed of water ring vacuum pump, steam water separator, heat exchanger, one-way valve, water supply solenoid valve, ball valve, pipeline, electric contact vacuum gauge, control cabinet, frame, etc. its main function is to make the working fluid in the water ring vacuum pump recycled, generally in the chemical industry and water resources comparison The water ring vacuum pump unit can be used by the deficient enterprises, so as to greatly reduce the sustainable utilization of water resources or chemical working fluid, thus reducing the cost of enterprises.
