Bootable disk didn't help me
Last Friday, I created a boot disk for my computer,(With USB) but it was strange that USB didn’t appear on the boot menu,
My iso file is 2.2 GB , i don’t know what is wrong with it .
Check your computer’s USB port to make sure the USB is fully plugged into your computer, or what do you use to burn iso ?
I got another way for it ,click this link that you can get them for making a bootable USB disk .
https://www.iseepassword.com/how-to-make-bootable-usb-drive.html
Have you tried the suggested steps? Is it working now?
Perhaps you need to format the disk again (you can even with the help of some program like Acronis Disk) and start this operation. I had the same situation when I wanted to transfer my research paper topics related to my work to another disk and I used this tutorial:
https://www.ionos.com/digitalguide/server/know-how/make-a-bootable-usb-drive/
I think that there was just an error somewhere, so you need to try again.
Perhaps you need to format the disk again (you can even with the help of some program like Acronis Disk) and start this operation. I had the same situation when I wanted to transfer the articles that I wrote with the help of  anonymous-essay.com to another disk and I used this tutorial:
I suspect you did some wrong in making a bootable disks,
https://www.uubyte.com/
http://www.freeisoburner.com/
Try if they help.Very few people fail with them.
It may happen if the image on your boot stick is corrupt.
Try loading the right image file to your stick and then try booting from it.
