Newbie
128GB SD card, now set to RAW file system and showing no/little storage
128GB SD card, now set to RAW file system and showing no/little storage.
It refuses to format to a different file system in my computer or diskpart.
yes is genuine card and it did work.
Why? and how do i fix?
please and thank you
SanDisk Guru
Re: 128GB SD card, now set to RAW file system and showing no/little storage
this sounds like a bad card. RAW just means there is no file system at all. if diskpart or other methods will not complete a format the card would need to be replaced.
Newbie
I think there is something wrong with the card.
