Newbie
Accepted Solution
sync problem
When I sync to my sansa clip zip with it syncs songs that are already on the device. I think its because the file modification date doesn't update. The modification date on a file on my hard drive would be 13/08/2012 but when you put the track on to the clip its 13/03/2005. So the program I sync with thinks the files need to be updated. Is there a solution to this.
SanDisk Guru
Re: sync problem
Yes. Don't sync.
SanDisk Guru
Re: sync problem
I would play with your syncing program some, and see if you can do something from that angle.
Newbie
Re: sync problem
its not a program problem its a problem with the mp3 player
SanDisk Guru
Re: sync problem
And had you set the date and time on your Zip originally?
Newbie
Re: sync problem
[ Edited ]
Yeah, the date and time is correct. Even if I use windows explorer to copy the files to the clip the mod date reverts to an old date.
SanDisk Guru
Re: sync problem
Stop trying to sync. Sync=sink! Don't fall into the abyss. Just copy and paste folders of files to the player in MSC mode. It is so simple and without drawbacks.
SanDisk Guru
Re: sync problem
Although I like simple drag-and-drop myself (it just works), I really don't see why the OP shouldn't use sync if that fits his needs--telling him not to sync really doesn't help him. Rather, why isn't the player seemingly playing nice with it?
SanDisk Guru
Re: sync problem
Why doesn't synch work? Often synch works unexpectedly or doesn't work at all. Sometimes too much automation is very counterproductive. There are so many posts of people mysteriously losing songs, or getting plenty of unwanted junk put on their player. Imo the whole concept of synching is flawed, and it should be avoided.
