Newbie
wrong firmware
i have (sdcz50-032g) Cruzer Blade USB Flash Drive 32GB, one day it's firmware crashed, and I had to search and download new one, so i found firmware but when I install it, my Flash drive's capacity become 8.08GB :-|
please help me to find suitable firmware to my flash drive
This is my new flash drive information after I formated to it's new firmware
Description: [E:]USB Mass Storage Device(Generic Flash Disk)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 058F PID = 6387
Serial Number: 46ED036C
Device Vendor: Generic
Device Name: Mass Storage
Device Revision: 010B
Manufacturer: Generic
Product Model: Flash Disk
Product Revision: 8.07
Controller Vendor: Alcor Micro
Controller Part-Number: AU6989SN/AU6989ANL [E50B] - F/W FF00
Flash ID code: ADDE94EB - Hynix H27UCG8T2BYR - 1CE/Single Channel [MLC-16K] -> Total Capacity = 8GB
SanDisk Guru
Re: wrong firmware
What OS are you using?  Are the files shown accessible?  If so back them up as soon as you can.  How did the drive get formatted to NTFS?  Is the drive partitioned?
Ed
Newbie
Re: wrong firmware
I'm using Windows 7 32bit
I'm can use the flash drive now, and I can format it to any file system I want, I can put files on it and delete them when ever I want.
My problem is, I need official suitable firmware for my 32 GB flash drive. Because It shows it's capacity is 8.08 GB, even if use partition program.
Sorry I can't explain very well, my English now that good.
SanDisk Guru
Re: wrong firmware
[ Edited ]
Your English is fine.
I don't recommend journelling type drive formats for flash drives.  The extra IO makes them slower and can wear them out faster.  If you use the drive for large files exFAT is a better choice.
Nothing in your original posting indicates your flash drive is a SanDisk drive.
Maybe you should talk to the source of the firmware you downloaded to see if they can help.  What was the name of the firmware you downloaded?
Ed
Newbie
Re: wrong firmware
"Nothing in your original posting indicates your flash drive is a SanDisk drive." because the the original firmware is crashed, and I used Unofficial firmware for my flash drive, I couldn't find firmware for my 32GB flash drive.
I downloaded the firmware from here :
http://flashboot.ru
SanDisk Guru
Re: wrong firmware
At this point all I can say is see if you can find some unoffical 32 GB firmware.
Or buy a new drive.
Ed
Newbie
Re: wrong firmware
Can you help me find 32GB firmware
SanDisk Guru
Re: wrong firmware
Sorry.  You have better firmware search skills than I do.
Ed
Newbie
Re: wrong firmware
Thanks anyway Smiley Happy
