usb 2.0 flash drive
How do I know when a file is done loading on my flash drive? thanks Bill
the window showing transfer progress will close. you can also look at the LED of the drive. depending on what version the drive is LED behavior will be different. see be low a list of all possible LED behavior.
  1. LED is a solid light and blinks only when transferring files to the device.
  2. LED blinks rapidly during initialization then turns off. LED then only blinks when data is being transferred.
  3. LED breaths (slowly fades in and out) when device is not being used and blinks rapidly when data is being transferred.
Tnank you.  Bill
