Newbie
ultra usb not properly detected by w10
When I connect 128gb ultra usb in w10, I receive following message: SanDisk Ultra USB unable to connect to host controller.  When I go into device manager under usb hub it shows a bad connection Unknown usb device (invalid device descriptor). Under :General it says
Windows has stopped this device because it has reported problems. (Code 43)
The USB device returned an invalid USB device descriptor.
usb works in a mac and is formatted for dos.
SanDisk Guru
Re: ultra usb not properly detected by w10
Is it new or used?  Did you format it?  I think you need to reformat it in the MAC.  exFAT would be the preferred format.  FAT32 won't work with a drive this large.
Ed
Newbie
resolved vmware issue
