Newbie
i need a firmware to SanDisk Cruzer Blade 16 gb 1.10
usb information
Description: USB Mass Storage Device(SanDisk Cruzer Blade)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 0781 PID = 5567
Serial Number: 200522434309F6B05D76
Device Vendor: SanDisk
Device Name: Cruzer Blade
Device Revision: 0102
Manufacturer: SanDisk
Product Model: Cruzer Blade
Product Revision: 1.10
Controller Part-Number: Unknown
SanDisk User
Re: i need a firmware to SanDisk Cruzer Blade 16 gb 1.10
I wouldn't suggest upgrading the firemware unless needed. If it's working fine for you, then just stay with it. What feature are you looking for if I may ask?
SanDisk Guru
That's going to be a little difficult since there isn't any firmware update for flash drives. Smiley Frustrated
