Highlighted
SanDisk Guru
Re: help pre installed software cruzer blade
Excellent links juliuscaesar.  Thank you for sharing them.Cat Happy
"I do not know English and use an automatic translator from Italian into English."
Well, that answers a whole lot of questions.  I was not aware of that.
Ed
Highlighted
Newbie
Re: help access sandisk drive-not accessing files-only short-cut reading
HI there
I need some please. Thanks. I have a 8 gb sandisk, with loads of music and other files.
If I put into computer, it just reads short-cut and something saying wmp info
If I go to properties, it says it is still full of stuff; but get an error message when try to open the short-cut or WMPInfo....
\blablabla blaxxxxxxxxxx.hyz module not found
I do not want to format this drive, plse
Thanks
Rgds Brian
Highlighted
SanDisk Guru
From a  Windows Command Prompt try running a CHKDSK command on the drive.  If it shows errors rerun it with the /f option.
For example:
C:\Users\Ed>chkdsk e:
Windows has checked the file system and found problems.
C:\Users\Ed>chkdsk e: /f
Ed
