Newbie
cruser edge 8gb formatted accidentally
Hi all
My cruser edge is accidentally formatted and is not  recognized on the computer any more. What do I do   to restore the usb drive to use it.
Thanks in advance for  your valued suggestion.
barb
SanDisk Guru
Re: cruser edge 8gb formatted accidentally
does it work on other computers? if not it is likely a bad drive. contact sandisk support.
Newbie
try to format it from DOS and see.
