Because ‘Right Clicking’ on the listing in Windows Explorer did not have a “Safe Ejection” entry, I have used a ‘Shortcut’ to, “C:\Windows\System32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll” and ended with, “The ‘SanDisk Cruzer Edge USB Device’ device is not removable and cannot be ejected or unplugged.”
This not at all what i thought I was buying when I obtained a card of four ‘Cruzers.’ Has anyone found a way around this?
Worst comes to worst, shut down the machine, then remove the Cruzer and reboot.
In Windows Explorer does the Cruzer show as a Removable Disk or a Fixed Disk? Did you possibly select the Windows ReadyBoost option in the Windows AutoPlay window when you plugged it in?
Windows Explorer definetly does not announce/label the Cruzer as “Removable.” I do not recall changing anything on the first auto-detect but then I have reformatted one of the four drives as NTFS from FAT32. But all Cruzers are seen as, “Non removable.” whether NTFS or FAT32. There must be a Registry entry that identifies whether or not an le oUSB device is removable.
"But all Cruzers are seen as, “Non removable.” whether NTFS or FAT32."
If you RIGHT click on one then on Properties what Type does the Properties window’s General tab show?
On the Properties window’s Hardware tab click on the SanDisk drive’s name then click on the Properties button at the bottom of the window. On the Device Properties window click on the Policies tab. What policy options are enabled?
Here’s how I cleared my problem by using an untouched, fresh new, Cruzer 8GB:
i) I saved everything on the NTFS reformatted & renamed Cruzer 8GB which Win7 reported as non-removale after I 'messed with it.
ii) I copied everything from a FAT32 formatted, freshly purchased, Cruzer 8GB, which Win7 reported as removable to the drive in i)
now the drive in i) was reported as removable
iv) Finally I replaced the data saved in Step i) above, onto the problem Cruzer drive
Guess I’ll put up with the extra files. This is much better than rebooting each time i wish to remove a ‘thumb drive’; even though I have a faster booting SSD C: drive.
Same thing happened to me. Cruzer jump drive says it is not removable. This followed using it to run recovery effort on a problematic laptop. The cruzer was used to repair the laptop windows 10 os and seems to have done a good job (have iso image on the cruzer to use for the above purpose). Now I get a message returned that it is not removable when I try to safely eject it. Is the pc reading the iso image (windows 10) that is on the cruzer as now being my system files or a similar problem, do you think? I haven’t tried shutting down and removing in case the laptop now thinks it “needs” the information/iso on the cruzer to even boot. Any help or thoughts would help, Thanks
Safely Remove ensures any writes sitting in a Windows buffer gets written to the drive. These writes could be very small, like an update to a file directory entry, but could be very critical to the data on the drive being usable. If Windows says the drive is not removable means something has a file or folder open on the drive. Be sure everything using the drive is closed. If unable to determine what is using the drive shutting down Windows works. And I don’t mean turning the system off, I mean shutting it down.
