Newbie
Re: Ultra Fit USB 3.0: Excessive Heat
I believe you will find that it isn't poor design, but rather that the Ultra Fit are USB 3.0, whereas the Cruiser Fit is only 2.0.  USB 3.0 uses more power, but it still doesn't seem as if they should get that hot.  I have the same problem, and perhaps it is a design flaw, but we can't compare it with the Cruiser Fit, because one of almost 10-times faster in file transfer speed than the other.
