Newbie
USB FLASH DRIVE
Just bought Cruzer Glide 128GB USB 2.0 Flash drive.  When I try to launch SanDiskSecureAccessV3.1_win  it gets stuck on "Searching for updates.....please wait."  Any help will be greatly appreciated.  Thanks!
SanDisk Guru
Re: USB FLASH DRIVE
Are you connected to the 'net when you do this?  If so does your system's security block the device's attempt to check for an update?
Ed
