Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
SanDisk Ultra USB 3.0 128GB Speed Down To 0Options
08-25-2019 03:04 PM
Hi my USB Stick Speed drop from 70Mb/s to 0 after some Seconds...I formatted it to NTFS with Rufus becauce FAT32 don't allow higher than 4GB Files. exFat is the best Option but it won't work fine on Win 7 x32...soo is it normal or damaged and has Anyone a fix ? It happen on all File Sizes, it Drop down and go up again but only to 20MB/s
Re: SanDisk Ultra USB 3.0 128GB Speed Down To 0[ Edited ]Options
08-25-2019 05:32 PM - edited 08-25-2019 05:34 PM The extra IO for the journalling is slowing it down. If you have your Windows configured for USB safety verses performance can impact it also. I'm pretty sure exFAT worked fine on my Windows 7 system.
Ed
Important files = Backed up files Re: SanDisk Ultra USB 3.0 128GB Speed Down To 0Options
08-26-2019 03:07 PM
I know that it works fine on Win7 but not on older PC's with x32 Versions
