SanDisk Guru
Re: SanDisk Cruzer Blade 8GB write protected error
Contact SanDisk for a RMA and send it to them for a replacement.
Ed
SanDisk User
Correct, I also worked before for a computer company. You check it first with tech support over the phone, and RMA if it's proven to be a hardware issue.
Newbie
About Write protection of cruzer edge 8gb
I tried REGEDIT method but still my usb shows write protected.
Newbie
Re: SanDisk Cruzer Blade 16GB write protected error
                I had the same problem. I tried many ways, different  methods from different  sites,even manufacturer didn't help me.  Then I found a very very good solution for remove the write protection from my sandisk pendrive ie; Throw it to waste bucket and buy a new one. Remember dont buy SANDISK. Because it has no technical support from manufacturer and other companies like TRANSCEND make less problems like this.
                                           okay...
        Regards,
                                                              sreekumariti@yahoo.co.in
SanDisk Guru
  TRANSCEND doesn't have a user's support forum like SanDisk does so if you have problems with their devices where you going to whine??
Did you write to SanDisk at all about your problem??
http://kb.sandisk.com/app/ask/
Ed
Newbie
Newbie
plzzzzz help me my usb sandisk cruzer edge is showing me write protection error how can i remove it my files do not go inside and files presnt in it can be deleted
Newbie
sry files cant be deleted
Newbie
i have tried every thing possible
Newbie
This is to inform you that, i am also facing the same problem;' the disk is write protected.
How can i solve my problem? plz guide.
otherwise tell, how would i refund to u. ?
