Highlighted
Newbie
Remove write protection from USB drive
One SanDisk Ultra USB 3.0 32GB drive decided it was time to be write protected. Diskpart showed that the disk was currently in a read-only state.
C:\WINDOWS\system32>diskpart
Microsoft DiskPart version 6.3.9600
Copyright (C) 1999-2013 Microsoft Corporation.
On computer: MEINCOMPUTER
DISKPART> list disk
  Disk ###  Status         Size     Free     Dyn  Gpt
  Disk 0    Online          111 GB      0 B
  Disk 1    Online          465 GB      0 B
  Disk 2    Online         1863 GB      0 B
  Disk 3    Online          698 GB      0 B
  Disk 4    Online           28 GB      0 B
  Disk 5    No Media           0 B      0 B
  Disk 6    No Media           0 B      0 B
  Disk 7    No Media           0 B      0 B
  Disk 8    No Media           0 B      0 B
DISKPART> select disk 4
Disk 4 is now the selected disk.
DISKPART> attributes disk
Current Read-only State : Yes
Read-only  : No
Boot Disk  : No
Pagefile Disk  : No
Hibernation File Disk  : No
Crashdump Disk  : No
Clustered Disk  : No
After a number of attempts suggested by Internet I decided that it was time to give up and give in to the dark side.
This was a FAQ entry at EMTEC:
My flash drive doesn't work / My flash drive is write protected
HOME › FREQUENTLY ASKED QUESTIONS › USB FLASH DRIVES
You can try restoring flash drive by using that "Restore" tool (backup data before): Download link: http://www.emtec-international.com/sites/default/files/drivers/restore.zip If it doesn't fix the issue, flash drive should be returned to the store where it has been purchased to get a replacement. Process to restore: 1) Plug the flash drive (certify that only the EMTEC flash drive is plugged) 2) launch restore.exe 3) Press the button RESTORE 4) A warning message is displayed about erasing data. Press RESTORE to continue. 5) A confirmation message is displayed, then press the YES 6) A message RESTORING DEVICE ... appears. Do not unplug the flash drive and wait for the restoration (1 to 2 minutes).
The download link is also dead but I found a program that fit the description. Ignoring the "certify" part and following the instructions I now have a working SanDisk USB drive. An empty one but at least I can use it to unimportant file transfers.
This is a copy of the program. Use at your own risk...
https://minfil.org/H2D3n6b2bb/Restore.zip
I will never buy a SanDisk USB drive again.
Highlighted
SanDisk Senior User
Re: Remove write protection from USB drive
in that case the drive is defective and needs to be replaced:
here is the link for the replacement:
http://kb.sandisk.com/app/rmaform/session/L3RpbWUvMTQ2NzEwNzcwOC9zaWQveVU4d2FhVW0%3D
Highlighted
SanDisk Guru
You are aware that this could happen to any flash drive regardless of manufacturer, right? Smiley Frustrated
Highlighted
Newbie
Yes. I will try and see if they grant me RMA of a "currently" working drive that is without a proof of purchase.-) I am trying to get it to fail again using "H2testw" endless write/verify.
This is not the first time a SanDisk drive has given me problem. It has been drives that have identified themself as "Local Disk" instead of the expected "Removable Disk" which created a lot of problem with programs that apperantly only works with a "Removable Disk". Drives that suddenly stopped working in any USB input on one computer but continued to work in other computer. Drives that sometime didn't work in a certain USB port when every other USB drive always worked.
All of this I have never seen from any other "brand" USB drive. No more SanDisk for me
Highlighted
Newbie
I have had the same issue and sent it off for a replacement.
Why are SanDisk USB drives setup with this unremovable write protection? not very user friendly is it.
Highlighted
SanDisk Guru
It beats the other option, of dying and everything being lost.
Ed
