Newbie
RAW SanDisk USB flash drive
Yesterday, I used my SanDisk USB flash drive on the computer of my friend for transferring some self-made videos. There was nothing strange or abnormal. But, when I plunged this USB flash drive back to my computer, it became weird. I just cannot access any files stored there and its file system also was turned into RAW. Is there some solution for me to access the files insider this USB flash drive? Or I should format this USB flash drive to fix it? I need your help! Thank you!
SanDisk Guru
Re: RAW SanDisk USB flash drive
Did you use Windows Safely Remove function to extract the flash drive on your friends machine?
If you can't run chkdsk for the flash drive then reformating may be your only option.
Ed
SanDisk Guru
[ Edited ]
Say Eugene343, how much does the Download cost ($$) that is shown in this image?
SPAM
You know, the one you have to Download and install to actually Recover the file you've selected.
Ed
SanDisk User
This can also be infected with a Virus or malware. try a scan first for both then you can format it if that's an option for you.
