Newbie
Problem with sandisk 64gb drive 3.0
So i bought a sandisk ultra fit 64gb 3.0 usb drive and in cant get bleemsync to work,i tried another drive and that one works fine(32gb)
When i look on the compatibility list ot should work tough..
The classic only blinks the led on the usb drive once,so is it possible im having a power issue and need a powered usb hub?
Thanks in advance
SanDisk Guru
Re: Problem with sandisk 64gb drive 3.0
FWIW 32GB drives are formated as FAT32, 64GB drives are formated as exFAT.  bleemsync support exFAT?
Ed
