Highlighted
Newbie
PROBLEM! This vault could not be loaded, it may be located on another computer
[ Edited ]
Hello all,
I have a big of a problem, i cant access my files.
Im using this stick since 2-3 years and never had any problems
suddenly i cant access my files because it tells me
This vault could not be loaded, it may be located on another computer or the original vault has been manually removed.
There was nothing i changed or did other than i usually do since years.
I googled already but couldnt find any working solution.  I contacted the support and iam waiting for an answer but
maybe some of u guys had the same problem and found a solution.
Pic in attachment
Highlighted
SanDisk Guru
Re: PROBLEM! This vault could not be loaded, it may be located on another computer
I think the USB Flash Drive showing 0 KB is a clue.  Run a CHKDSK command on the drive, then use the Safely Remove option to remove the drive.  Reinsert and see what happens.
Ed
Highlighted
Newbie
Nope, didnt help.. sadly
thx tho!
Highlighted
Newbie
Highlighted
Newbie
[ Edited ]
This is inside my Stick and i really dont know if there is something wrong!
Highlighted
SanDisk Guru
Try the drive in a different pc.  If it works extract ALL your files to another drive for backup, in case you have to replace/return your flash drive.
Ed
