Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
My Sandisk 64 GB flash cannot read on my Smart TVOptions
11-15-2018 10:28 PM
Hallo there,
i recently bought a 64 GB sandisk flash drive and had movies put. however, when i put in my smart TV, the TV doesnt sense the flash at all. However, the TV is able to sense and play other flash drives. What might be the problem. Please help me. Re: My Sandisk 64 GB flash cannot read on my Smart TVOptions
11-16-2018 07:25 AM The 64 GB drive is formatted as exFAT to handle large files and I suspect your Smart TV apparently can't handle exFAT format drives. The TV may need an update or a setting changed.
Ed
Important files = Backed up files |
