Newbie
My SD-CARD (32GB) is Original or Fake.?
hey there and supporters..
is there anyway find out my sdcard is original or fake..? write speed is very slow..
Card Reset Done!
Initializing Micro SD Card...
Card Initialized OK (V2.0 Compliant)
Waiting for IDLE State...
Card is now IDLE!
Reading Micro SD Card Information...
Manufacturer ID : 0x00
Application ID : 0
Product Name : APPSD
Product Revision : 0.0
Serial Number : 12815DB3
Manufacture Date: July 2018
Card CID: 00300041505053440012815DB3012751
Card CSD: 400E003253590000F9FF7F800A40003F
Card SCR: 02B5000000000000
Card OCR: 00C0FF8000
SD Card Size : 33554432000 Bytes
SD Block Size: 512 Bytes
Maximum Speed: 25000000 Hertz
SDHC / SDXC Card Detected...
Checking Lock Status...
Micro SD Card is NOT Password Protected!!!
SanDisk Guru
Re: My SD-CARD (32GB) is Original or Fake.?
You can call SanDisk. With the serial # they can verfiy authenticity.
https://www.sandisk.com/about/contact?_ga=2.234222171.417209992.1543254773-2076275964.1541613016
