Newbie
Accepted Solution
Login Problem
"An error occured. Please make sure you have enough space on your
external device and you are not launching the application from a
zip file. "
Everytime i want to connect into my vault , this error appears
Please anyone help me
SanDisk Guru
Re: Login Problem
[ Edited ]
Open Windows Explorer, open the flash drive's drive letter, delete all the files that you see.
That should take care of your forgotten password problem also.
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Forgot-Password/td-p/293095
Ed
Newbie
Re: Login Problem
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Login-Problem/m-p/293103#M4709
Ed, this link does not seem to work.
I have lost my password, and need help.
Thanks,
Em
Newbie
Re: Login Problem
Hi Ed,
I got your previous reply, ie to delete all filed on the drive through Windows Explorer.
Please advise whether it would let me set up a new password.
Many Thanks, Em
SanDisk Guru
Re: Login Problem
Once the files are all deleted the password capability will be gone also.
Ed
Newbie
Re: Login Problem
Ed, Many thanks for your prompt response.
Is there any way the Password capability can be reinstated and register a fresh pw?
Appreciate your help, EM
SanDisk Guru
Re: Login Problem
[ Edited ]
Yes, download and reinstall SanDisk's SecureAccess app.
And once a password is reestablished, WRITE IT DOWN!!  Store it in your wallet, purse, glove compartment, next to your pc, etc.
Ed
Newbie
Re: Login Problem
I sure shall do so.
Thanks, Again.
Newbie
Re: Login Problem
hey i have forgoton my password is thre anyway i can delet pass and keep ma data or anythig? please help
SanDisk User
Re: Login Problem
Is the drive encrypted using AES-128? If yes, without your password, you will not be able to recover any data on the drive. If you cannot remember your password, you will have to start over (which means deleting all data on the drive.) It has to be this way because, any type of backdoor or insecure entry point means the bad guys can then exploit these vulnerabilities to damage or steal files.
