SanDisk Guru
Re: HELP!!!!! how do i reomove 'write protected' message from my 16gb flash drive?
3.3 definitely works.
Be sure to backup your files before doing it.
Ed
Newbie
One problem with returning the drive (San Disk 256 GB Cruzer)- it has sensitive information. Is there a work around without returning the device? I purchased this at Costco within the last month (or thereabouts); I think I have the receipt. Without the receipt, I guess this is a no-go from the start, correct?
For the record, the first one ( a few more months back) has not had this issue.
Device details: SanDisk Cruzer Glide 3.0 1.00 [250.45 GB] (489160704 512-byte sectors)
thanks,
SanDisk Guru
[ Edited ]
Costco should be able to check your purchase on their system even without a receipt.
You can also return the drive to SanDisk for a replacement.  And with them it is possible to smash the drive with a hammer before returning it.  Do verify that with them before doing it.
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
Ed
