Highlighted
Newbie
Extreme Pro USB 128gb Write very Slowly
[ Edited ]
Hi, everybody i've purchased  2 weeks ago 2  extrem pro 128gb USB
i have used only 1  daily basis  and now the maximum writing speed doesn't exceed 80MB/s
and this speed  is slowing down to 30MB/s    and sometimes no faster than 15mb/s
and that with files (videos) not unlimited small files copy.
what's the matter  the usb stick got only 2 weeks
2nd point  the usb stick  is very very HOT,  i thought was the temperature that slowing down the write speed and
put a fan to cool it   but   still  slow writing.
and i noticed that between many files serial copy  there's like a moment the copy get stuck
also the size of the usb stick in explorer disappear and  re appear
sounds to me like the stick dead.
i have  a sandisk Ultra 128gb  that working very better  (faster tha the extreme pro!!!!!) and has been used  for a year now  and no probem
is there something i can do or do i have to send it back ?
thanx for your help
Highlighted
Newbie
Re: Extreme Pro USB 128gb Write very Slowly
Hey, try format the drive,
[FOR WINDOWS ONLY]
Right click at the drive, click format, DO NOT CHECK QUICK FORMAT (Slow but nessesary)
then check if the drive performed better, if not, reply
Highlighted
Newbie
, thanx very much for your answer
It solved my problem
the writing speed is back to normal.
yanhx again
