Highlighted
Newbie
Drive failure
My flash drive (San Disk Firebird 6Sp9) is no longer accessible (since this morning).  Whenever I try to access my data, I get “You need to format the disk before you can use it …”. My laptop (running windows 8.1) installed some updates when I shut down yesterday, and again when I booted up this morning, since then I have been unable to access my external drive.  I get the same error on other computers, one of which is running Windows 7. I have tried a recovery program, with no positive result. What else can I try?
I see the following event for Removable Disk (ESmiley Happy, Properties, Events
  • Header: SanDisk Firebird USB Device Properties:
  • Timestamp: 7/18/2015 10:29:02 AM
  • Description: Device Configured (disk.inf)
  • Information: Device USBSTOR\Disk&Ven_SanDisk&Prod_Firebird&Rev_1.07\0123456789ABCDEF&0 was configured. Driver Name: disk.inf
  • 2nd entry with similar description and Information “Device Started (disk)”
Device Manager-E:\
  • Level: Information
  • Source: UserPnP
  • Task Category: (7005)
  • Event 1 General Description: Driver Management concluded the process to install driver wpdfs.inf_amd64_0e729876a834cfea\wpdfs.inf for Device Instance ID SWD\WPDBUSENUM\_??_USBSTOR#DISK&VEN_SANDISK&PROD_FIREBIRD&REV_1.07#0123456789ABCDEF&0#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B} with the following status: 0x0.
  • Event 2 General Description: Driver Management has concluded the process to add Service WUDFWpdFs for Device Instance ID SWD\WPDBUSENUM\_??_USBSTOR#DISK&VEN_SANDISK&PROD_FIREBIRD&REV_1.07#0123456789ABCDEF&0#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B} with the following status: 0.
Device Manager-SanDisk Firebird USB Device
  • Source: Kernel-PnP
  • Task Category: 410
  • Event 1 General Description: Device USBSTOR\Disk&Ven_SanDisk&Prod_Firebird&Rev_1.07\0123456789ABCDEF&0 was started.
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Service: disk
Lower Filters:
Upper Filters:
  • Event 2 General Description: Device USBSTOR\Disk&Ven_SanDisk&Prod_Firebird&Rev_1.07\0123456789ABCDEF&0 was configured.
Driver Date: 06/21/2006
Driver Version: 6.3.9600.16384
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0006
Matching Device Id: GenDisk
Outranked Drivers: disk.inf:GenDisk:00FF2002
Device Updated: false
Highlighted
SanDisk Guru
Re: Drive failure
What else can I try
I would try running a CHKDSK command on the drive,
CHKDSK x: /F
where x is the drive letter assigned to the flash drive.
Ed
Highlighted
Newbie
Re: Drive failure
Hi Ed,
The response to CHKDSK e: /F is:
The type of the file system is RAW.
CHKDSK is not available for RAW drives.
Is there an alternate command for RAW drives?
Thanks,
Diane
Highlighted
SanDisk Guru
Re: Drive failure
At this point if the files on the drive are important to you I recommend finding a professional service to try to recover them.  If the files are not important you can try reformating the drive or simply buying a new drive.
Sorry.
Ed
