tasver
1
Hi all, i would like to buy one 32GB usb from amazon but in sold there are two models with the same price…
This it was added on amazon.it on 21 july 2013
SDCZ80-032G-G46
http://www.amazon.it/SanDisk-Cruzer-Extreme-Drive-Nero/dp/B00DZPUOU8/ref=sr_1_1?s=pc&ie=UTF8&qid=1409387764&sr=1-1&keywords=sandisk+extreme
This one it was added on amazon.it on 16 september 2012
SDCZ80-032G-FFP
http://www.amazon.it/Sandisk-SDCZ80-032G-FFP-Extreme-Imballaggio-apertura/dp/B0095SIH2Q/ref=sr_1_9?ie=UTF8&qid=1409389584&sr=8-9&keywords=sandisk+extreme+32
1)There are some difference from each other?
I suppose the first is newer revision i’m confused…
- What usb do you suggest me to buy?
THanks for your attention ^^
ed_p
3
Well, are either of the devices new? Or have they been used? If used what is the return policy of the seller?
Are bootbale usb keys?
Sure, Easy2Boot will make any USB drive bootable, new or old.
