Newbie
DEFAULT BLOCKSIZE CRUZER BLADE 64GB
After formatting a Cruzer Blade 64GB it no longer works in my music centre.
What is the original default format (ex FAT or NTFS) and blocksize so I can restore this?
Thanks.
Niel.
SanDisk Guru
Re: DEFAULT BLOCKSIZE CRUZER BLADE 64GB
The default format for anything larger than 32 GB is exFAT.  As for blocksize let Windows figure it out.
Ed
Newbie
Thanks,
Actually that didn't work, I tried that first before the post - it was not recognised.
I ended up formatting to NTFS with 4096kB - which worked. Shame the audio manual does not tell me what will be recognised either (Maranz unit).
So are Cruzer Blade USB's ex factory exFAT and what blocksize?
