Highlighted
Newbie
Cruzer Edge 16Gb & Cruzer Glide 64Gb both copying slow
[ Edited ]
I have set High Performance in Device Manager on both of them, but they still BOTH copy at approx 14MB per sec, and this is using USB 3.0 Ports (and yes, I realise the Edge is only 2.0).
Why are they performing so poorly?
Highlighted
SanDisk Professor
Re: Cruzer Edge 16Gb & Cruzer Glide 64Gb both copying slow
you see both drives are simple usb 2.0 storage drives and not manufactured for high speeds, so even though you use them on a usb 3.0 port the speed will remain at 2.0 because the drives are only 2.0. in order to see higher speeds i would recommend using an usb 3.0 drive that will actually reach higher speeds and performance.
Good Luck
#Missing the keyboard? Press F1 for help#
Highlighted
Newbie
[ Edited ]
My mistake, I wasn't aware that the Glide was only 2.0, so are you saying that these speeds are accurate for both drives?
Highlighted
SanDisk Professor
Yes there are both normal usb 2 storage drives. so the speeds should be around 20mb like all the normal storage drives
Good Luck
