Highlighted
Newbie
Cruzer Blade 32GB
I am unable to transfer files. I keep getting told 'unable to create directory'. I already have 11 GB of files on it. Can anyone explain why this is happening?
Highlighted
Newbie
Re: Cruzer Blade 32GB
Forgot to add that I am running Win 7 SP1 x 64
Highlighted
SanDisk User
Hi, are you trying to write files to the flash drive? Or from flash drive to PC?
Highlighted
SanDisk Professor
in that case i see you are using the secure access software that was included inside the flash drive. in that case you can backup the vault folder and format the drive on ExFat. then you can store the vault once more inside the flash drive and try to add more files inside the secure access.
Good Luck
#Missing the keyboard? Press F1 for help#
Highlighted
Newbie
It seems the problem is with the security permissions on your profile temp folder.
Recheck the security permission.
