Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Connecting my flash driveOptions
12-10-2018 07:02 PM i just received a sandisk ultra usb 3.0 flash drive (48-256G-A16S) with a female adaptor. 1 what cables do i need to connect it to my pc and smartphone ports, which have female adaptors? 2 what cable for a usb 2.0 port? 3 are there any double male adaptors without cables? Re: Connecting my flash driveOptions
12-12-2018 10:00 AM just figured out that it has a tiny button on top to push out the male connector. duh Re: Connecting my flash driveOptions
12-12-2018 02:30 PM Thanks for the update g/t. Always like happy endings.
Ed
Important files = Backed up files |
