Highlighted
SanDisk Guru
Re: 8 GB sandisk cruzer is read as 0 mb
Or maybe the drive was yanked out rather than Safely Removed and the FAT is all screwed up.
Ed
Highlighted
SanDisk Guru
@jamest89 wrote:
I was searching around as my sanddisk memory card got problem, non of the answers above helps, anyone got any solution?
Sorry, but if someone did it would be posted here somewhere. Smiley Wink
Highlighted
Newbie
No need to be panic.Google some methods or free data recovery software to help you. But I am fully convinced there is no such thing as free lunch. I trust Kvisoft Data Recovery Software.
Highlighted
SanDisk Guru
[ Edited ]
Free apps can be found here:
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/Download-new-version-lost-access-to-all-da...
Free to download AND free to use.  And if they don't work then you can try the $69.95 SPAM option. Smiley Very Happy
Ed
Highlighted
Newbie
I suggest that you try some SanDisk Cruzer data recovery solution, here's some I found from google
usb flash drive data recovery
How to recover Sandisk files
Sandisk Cruzer file recover
Highlighted
SanDisk Guru
[ Edited ]
Wow!!  Really?  But $39.95 seems a little much to pay for your app when there are others that are completely free.  And you don't even have to use Google to find them, just scroll up 2 postings.
Sounds like you're a SPAMmer johnwondershare.
Ed
