Highlighted
Newbie
8 GB sandisk cruzer is read as 0 mb
My 8 GB sandisk cruzer is read as 0 mb and i cant access any of my files on it or save files on it.  i have tried formating it in windows7 by right clicking the drive and i have tried in disk management, i have also tried gparted.  for some reason in linux i can read and copy files for a mabe 1 min befor the light on the drive starts flashing rapidly, after that i have to restart linux to do any thing with the drive.  so i was able to get any thing i needed from the drive and now i just want to fix it.  linux and windows agree the drive is formated in FAT32 but a few days ago it was acting like it was formated with FAT16 and could not fit mor than 2 gb of data but did not go to try and fix that untill today and found this new problem.  i have also tried to reset it to factory setting with the u3 installer and it said it was not a sandisk drive.
i have tried the drive on several diferent operating systems xp, vista,7,ubuntu 11.04
i already got the data i needed so i am willing to do what ever it takes to fix the drive.
Highlighted
Newbie
Re: 8 GB sandisk cruzer is read as 0 mb
I am having the same problem with my 16GB Cruzer Blade aand would like
to fix it not bothered about losing the files on it ,but world like to be able to
use my drive again as its only about 10 months old and has not been used much
thanks for any help with this issue
Highlighted
Newbie
I have been talking to sanDisk about this problem and now
all of a sudden they have disabled my account so I can no
longer login, seems to me they are brushing this problem under
carpet so to speak
Would be nice to get some support or a replacement drive as its
still under warranty, they told me to return it to the seller but they only
have return on the items they sell.
Highlighted
Newbie
True, even I am facing the same problem on the 8GB sandisk cruzer that I purchased hardly 5 months ago.
I use cyber cafe and have been using this pen drive as a means to port my data. About 45 days ago, I was using it in the same manner.
The drive was connected to the computer and was working perfectly well for about 2 hours and suddenly it developed some snag which I am not able to understand what.
It now reads as 0 MB. It neither permits write, nor am I able to access the 1.76 GB of data that is stored in it. I tried formatting it through means known to me, my cyber friend. None of it has worked.
The more I analyse the situation, the more I get to think that the the factory embeded software (firmware) has been infected with an unknown virus. True that firmware does not get corrupted/virus infected. Yet,......
Highlighted
Newbie
You can try using the HP format tool in order to format the flash drive. You can refer to http://files.extremeoverclocking.com/file.php?f=197 for downloading the software.
Im a nobody.. nobodys perfect.. therefore IM PERFECT!!!
Highlighted
SanDisk User
The Sandisk Cruzer 16 GB is formatted as FAT 32. This gives a maximum file size of 4GB. You'll have to format as NTFS.
___________________________________________________________
Highlighted
Newbie
Highlighted
Newbie
So i finaly  **bleep**ing fixed my problem it was so easy i just layed it down safelt (my 16gb) and smashed it witha hamer now my problem is fixed (:............................................... but no realy i smashed it );
Highlighted
Newbie
Just got the same problem here.  Cruzer 8GB, was copying a roughly 2GB file to it.  Got about 75% of the way done then I got a message saying Windows (7) could no longer see the drive.  Now everytime I plug it in the light does it's normal thing but as soon as I try to access the drive it starts blinking rapidly and continues to do so even after I tell Windows to eject it.  I am unable to format it either.
Except for the smashing it solution, has anyone got anything else to work?
Highlighted
Newbie
Maybe the drive you have is counterfeit Sandisk with a faulty flash memory or fake set capacity. You can try running the H2 burn in test to verify the quality, otherwise try filing a RMA under Sandisk's warranty. For more info on H2, have a look at my site.
http://www.chinaelectronicsinsider.com/technical/how-test-fake-flash-memory
Delve deeper into China's electronics workshop
China Electronics Insider
